MrMetric
This is for all of you out there that have finished with your Little Hercules and Silver Eagle plans after you built your engines. I purchased some casting kits from an estate and, unfortunately, the plans had been separated from the casting kits. For that matter, two of the flywheels were also missing for the Silver Eagle engine, for which I'll have to figure out an alternative (probably make my own). I've contacted the new owners and we'll see what they have to say... But the best solution would be to find someone that has a set of plans that are no longer needed. I'm looking for both the drawings and the suggestions sheets.
I can help you clean out your files of stuff you no longer need, and you can get a few dollars in the process.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
