Level of precision
Imho not something needed or particularly valuable for a home shop model maker.
The web page states under application.
Best for boring operation in shipbuilding, bridge building, framework building, and steel structure building.
Has anyone used these before?
When i worked in a steel fabrication shop we used similar bits for drilling the holes in the steel beams and columns.
so unless you are going to build a steel building bridge or ship NO.
Do they produce a precise hole or is this tool used for roughing?
A rough hole as they are intended for a large bolt to go though.
Typically in a machine shop one drills a hole with a drill bit then enlarges the hole with a boring bar on a lathe or boring head (with boring bar) on a mill.
Tin
I have used similar tools for the last decade. Some very high precision, some horrible. Most people refer to them as a holes saw or hollow mill. Those appear to be carbide tipped and of high quality.
I must ditto Tin in the previous post. For a home modeler those would probably never get used unless you used it just to use it. In the last 10 years I've used those on 3 different parts, all with out the pilot for the specific purpose of leaving a post.
Also google: annular cutter
Spend your money on something more useful... you can never have to man 1/16 to 5/8 or 2mm to 12mm endmills. Trust me.
