Recently i decided to modify the tailstock to a lever feed type(fed up with winding handle),To this end i removed the handle from the outboard end and after an examination of the mechanics involved thought i could get away with merely extending the length of the original feed screw and fastening the associated linkage to this. Duly made up extension and fitted , every thing was as expected and worked fine and indeed the system is a delight to use . However it will not eject the morse taper , could someone please tell me why and if possible offer a solution.
I do know that the original arrangement depended on the screw being extended to eject the taper but cannot see an alternative while still having a lever feed.
regards
coldte
regards
coldte
