Hi all!
I have done a lot of research and need some specific help.
Here's the deal, I need a lathe to make some parts in my dad's woodworking shop (industrial shop) but also want the capability to make engines as well.
The parts are not real big (biggest one is about 3' long and a few inches in diameter) and fairly small (odd nut and bolt sized parts that are fairly simple). They need to be quite acurate, a thou or so.
What's a good size? Where the shop is leased there is a metal fabrication shop that has a Jet 13x40 lathe that they don't use and want to get rid of it (aka, sell) and it's seems to be tight, will get my machinist friend to check it out thoroughly though.
He already said that he recomends a good import for a starter machine because they are easier to use and have bells and whistles that make life much easier for the novice and experienced alike. What's your opinion?
What are the limitations on this lathe if any for engine building something like an 100cc or so V8 (ultimately that's what I want to build).
Would I be better off with old iron (I think he'll take about $1500 or so with out the 4 jaw chuck.) for the same price as an import?
The lathe is from 1970 (I will double check that though) but hasn't seen much use, looks just like the new Grizzly version.
Am I better off with a smaller new machine? Or save up for a new 13x40 lathe?
I have 3 phase power and enough room for even a large lathe like a 20"x96" so that's not an issue.
I comes with basic tooling, some carbide insert stuff as well.
My budget right now is about $1500 but if you guys thing I will be better off saving and buying something better I can do that as well, trying not to spend more that $3000 though.
Currently there isn't anything in my area that is as good for the same price import or domestic so I will keep you posted if one pops up (checking CR twice a day).
I live about 10/15 minutes from Grizzly so customer support is very convinient with them (they have been good to me so far).
Any thing else I need to know just give a shout!
Thanks a bunch,
John.
Thanks a bunch,
John.
