Large coles hit and miss engine
Wayne j
Canada
Hi everyone, I just bought a large coles hit and miss engine. Been struggling for couple days getting it running. I’ve got the timing the best I can but still fires way too soon before TDC. Does anyone have the plans for this and would share a picture of the cam? This one is a really odd shape so I would like to make sure it’s not my issue. Any help is greatly appreciated!!
Wayne
  • Like
Reactions: Zeb
Catminer
Hi Wayne, it's been a lot of years since I built mine but I have the drawings stashed somewhere, I will look
for them.
I will try to get a picture of the cam also, if possible. The engine is mounted in my version of a hit and miss tractor and it may be difficult to get a picture.
Peter
Wayne j
Canada
Thank you Catminer for sending me the info I need to confirm Cam is ok. I am new to hit and miss engines and what confuses me is that using this cam with a Buzz coil t it provides spark during many of the 4 strokes except the exhaust cycle. I thought it should only fire once when the engine is TDC on the compression stroke. Anyone’s insight into this would really help. I know there’s lots of knowledgeable people here. Thanks
Wayne
Vietti
HMEM Supporting Member
Thermopolis Wyoming USA
Move the slider on the push rod that triggers the points, time it staticaly till the points break at tdc, a thin piece of paper works too or a VOM. When the points release the paper you know the points just opened.
Wayne j
Canada
I had the understanding the the buzz coil and the plug fires when the points come into contact NOT when they separate? Am I wrong?
Catminer
Hi Wayne, So far I have failed in finding the drawings and cannot not get a picture of the cam on my engine.
I will look some more.
This ignition system is for a single spark high tension coil ignition, spark will occur when the points open.
The points closed time (dwell) is the little cutout in the lower right of the cam as you have it pictured.
I use a 6v automotive coil and four D cells or a lantern battery as a power source.
Peter
Wayne j
Canada
Thanks Peter MNay sent me what I needed for drawings. The cam is ok. The engine came with a buzz coil. Will that work for this type of engine? Or do I need a single spark high tension coil? I am new to this, I usually work on steam engines.
Wayne
Catminer
Wayne, a buzz coil will not work with the cam configured as it is. It needs to be a single spark coil.
Peter
Wayne j
Canada
Peter
Thanks Peter!! That confirms what I was suspecting. Having limited knowledge of these engines I could not get my head around how this could produce a single spark at TDC. It was sparking at too many points in the 4 strokes. Now I just have to figure out how to set up a single spark coil! My hands are really blistered from spinning those wheels on this engine for 2 days trying to get it to run!!!
Wayne
Wayne j
Canada
When you use an automotive coil does the negative on coil go through the points and the top connector on the coil go to the spark plug? Thx
Catminer
Correct, the neg terminal on the coil goes to the points. They are a switch to ground. Don't forget to add a capacitor parallel to this part of the circuit.
And the large centre terminal is the high tension lead to the spark plug.
