Jaws for Buck chuck
Help Support HMEM:
blockmanjohn
Hi,
I'm just taking a long shot here, but I am looking for a set of outside jaws for my Buck chuck. It is a 6" adjus-tru, 3 jaw chuck model 3634. Nothing on E-Bay and I really don't expect to find them. You never know.
Thanks, John.
SmithDoor
Clovis Ca
Do have a two piece jaw???
Hi,
Thanks, John.
clockworkcheval
Active Member
You may be able to make do with soft jaws from Aluminium which you bolt onto the regular jaws. I use them mostly for discs but it should be quite possible to use them for cylindrical parts too. As long as you preload the soft jaws when machining them at the right diameter. For me the right diameter is slightly undersize as this gives you six lines of contact rather than three.
MachineTom
Senior Member
HMEM Supporter
Please post the dimensions of the jaws
'm width, groove width, height.
I have some unknow jaws.
Tom
comstock-friend
Sun Valley, California
Tom
I also have a pile of useless (to me) chuck jaws, but need to know what yours look like to compare. (And ebay always has chuck jaws listed, but the same problem, they don't tell you the critical dimensions.)
Also, Buck exists, but being a Hardinge company, you will have to dig deep...
SmithDoor
Clovis Ca
Try 4 Jaws Combination Independent & Self Centering Manual Lathe Chuck
Great for making a few odd shape parts.
blockmanjohn
Hi Tom,
The inside jaws I have measure:
length-2.467
height-1.735
width-.738
groove width-.310
This should be enough information to start. Thanks for looking, John.
SmithDoor
Clovis Ca
Please post photos of Chuck and your other jaws
Hi Tom,
length-2.467
height-1.735
width-.738
groove width-.310
SmithDoor
Clovis Ca
It looks well used Chuck
Be for spending money jaws check the scol bearing for wear it should be a clearance of less than 0.0005"
Greater will give chucking problems.
Dave,
This is my Buck chuck #3634 with the ID jaws, John.
MachineTom
Senior Member
HMEM Supporter
MachineTom
Senior Member
HMEM Supporter
Sorry, my jaws are to small for your chuck.
H0$$
Texas
I would appreciate some information, I am looking for jaws for what appears to be a six inch six jaw buck chuck. I have the chuck but no jaws. Any advice is appreciated. Thanks Hoss
SmithDoor
Clovis Ca
Need to check the clearance of the scroll bearing.
A lot of chucks are worn out and if you have loss scroll your work will not be center.
