This might be in the wrong category but it looks like a nice idea for a small engine.
Someone asked a question in a 1936 Model Engineer mag about this type of engine and while not practical for power generation it might make a good conversation starter.
It's sound powered. A rod is connected between the vibrating magnet of a large microphone, old style like the would have used in the 30's (you would probably have to make one) and a ratchet wheel with fine teeth which is in line with a flywheel/pulley for "power" transmission. As the Mic receives sound it pushes the rod out and engages the ratchet which in turn rotates the wheel and drives the pulley. Each vibration of the Mic increments the ratchet wheel one tooth so the more sound there is the faster it rotates.
OK it's a bit hard to understand but there aren't any pictures to show it.
Just an idea.
Just an idea.
