I screwed up using a slitting saw
ieezitin
Lads
In the shot below is a set up on the milling machine of me trying to Slit-saw a taper pin expansion rod i am making. The saw thickness is .007 thou x 1 1/8th od, i ran the mill at 150 rpms the part is made out of 304 stainless.
In this shot you see the work in front of the slitting saw, i centered the saw blade to the pin center and i plunged cut in (moving the part away into the blade) .075 thou. that worked fine, i bathed it in Kroil and slowly fed the part onto the blade.
I then needed to slit the other side of it so i just raised the quill and moved the table 180deg, lowered the quill to center height and started to slit this side.
The device you see poking into the end of the collet block is a stop for the pin up in the hole, my thought was the blade may want to throw the pin out. That will become clearer on the next photos.
Here is a shot of the first side i successfully cut.
Well!!!!!!!!! here is what happened when i did the other-side, i got to about .050 in the cut and the thing turned to ****e, the blade snapped and at the same time gouged the piece which is now ruined.
Here is the shot of the part with the pin included, i installed a sacrifice pin into the arbor for the machining process in slitting, the wall thickness on the taper tube end is around .032 thou
I figured that what i am trying to explain may be a little hard to do in words so i can show you my drawings for you all to get a better perspective.
Linear drawing showing taper reamer and drill, this is to scale.
Detailed drawing.
And a shot of the pin installed before being turned down.
What i shall do now is re-make another one and this time just index the pin, as i know it worked in that location.
if anyone has any experience in using very thin slitting saws i would appreciate the advice, i have never slitted anything this thin.
Happy days Anthony.
Hi instead of starting from the end like you did
start from the middle go to your desire dep
and work your way out, by doing it this way
the metal that you remove will hold your blade
good luck
Based on looking at the part, Did you flip the sawblade and run the mill in reverse when trying to cut the second side. If you didn't you were climb sawing and that never works out.
Looking at the Dim's of the part the tube walls are less than .080 thick. When slitting thin tube you want the teeth to barely break through the wall, I' would have use a dremel type abrasive saw, like .015 IIR and in steady hands the results are quite good.
For a toothed blade you would need a saw of 40-60 tpi for cutting that thin a tube.
I have used a saw through a 5mm OD, 5/32" or 1/8" ID steel part. I've have cut through both sides in one pass and turn it over to get the last bit of full depth on the other side. I prefer to cut each side separately with a climb cut from the outside. The way I see it you can't risk a tooth catching the thin wall and pulling the part into the saw as the part will be flexible. I trashed one part trying just that. With a part this small the forces will be low and it will not move the table.
Greg
