Tim, should be the other way around: more positive is more likely to help.
I started out having a terrible time with parting. Much of it was my technique, some of it was my tooling. I wound up buying an Aloris indexable cutoff tool because I found one cheap on eBay and I like carbide tools. ;D
It was a big step up for me. Part of the big step up also came because I already knew carbide wants to be more aggressive, so I was a lot less tentative with this tool. The biggest problem it has is size. It wants to knock an 1/8" cut out of whatever you part, and sometimes that's too much. So, I got some nifty HSS parting blades that fit in a regular QCTP holder. They're ground with the same 3/8" or 1/2" square shank with a blade on the end. These too respond well if you feed them aggressively.
My tactic has become:
- Check center height and squareness really carefully before starting. It's easy to miss that the blade is slightly angled or that you're not on center. Make sure!
- Feed a little easy for just a small cut to test how well things cut. If you can't even get started at first, you have something seriously out of whack. Increase rigidity, change speeds, add coolant, but do something! BTW, I don't automatically assume coolant is needed, but it seems to help in maybe half the cases. I have a bunch of squeeze bottles (plastic condiment bottles) handy that have my coolants available: heavy sulfurized cutting oil, kerosene, and liquid WD-40 which is sort of in between.
- When that initial feed is cutting freely, I step up the feedrate to take as healthy a cut as I can. I let the chips be my guide. In other words, I feed harder so long as the chips peel off well, but you can see when you've just gone too far.
- If chatter still sets in, I first increase the spindle rpm slightly (1/4 turn on my speed control). If that makes it worse, I try decreasing. One direction or the other is nearly always helpful, and usually the increase is the better.
This last point relates to that idea of Constant Speed turning that Rick mentions. On a CNC, your spindle speeds up as you cut to smaller diameters so the surface speed on the tool stays the same. Have you ever been facing or parting (operations where you cut a lot of different diamters) and noted the cutting action suddenly got better? Your spindle speed may have been too slow for the larger diameter. If it gets worse, the opposite may be true. If you don't have variable speed, this may not help much. But if you do, a little tweak on the control may make things much nicer. If I take a lot of material off turning, I may even increase the speed a tad as I get to smaller diameters. You'd be surprised at how effective this can be.
BW
