Ok I got my HF tool grinder set up and got a new dressed ao wheel and spent the day grinding tools. Put a 2 ft. piece of 6061 on my Grizzly G4003G 12 inch lathe and made some tools. I experimented with positive & neg. rake, changed the clearance angles, speeds and feeds, depth of cut all to attempt to make a cutter to hog out aluminum. I think I know less now than when I started. So my questions are for hogging alum.
Positive or negative top rake?
End relief larger or smaller?
Side relief larger or smaller?
Round the nose or leave sharp?
Any sites I should look at? Did a search and most sites talk about how to grind a tool but not the job the tool in intended to be used for.
Thanks for any help
ed
Thanks for any help
ed
