Recently, I acquired a power hacksaw at an auction. I've been meaning to do up a photo-essay type of thing on this, but I've been rather busy lately with my very ambitious house marketing campaign (thanks again for the visits, guys, even if you're not particularly interested in my home, the blog is starting to be an excellent discussion on the subject of private sale!).
But that's not the point of this post. The blade that came with the machine had a huge chunk out of it that went "ka-thump" at one end of the stroke, so it needed to be replaced. I've been looking for a replacement blade that's around 1" x 12", and I remembered that there was a blade in the pile of things that was on or under the original bench.
So, checking out this blade, I found that it was about an inch too long. I knew that I'd never be able to drill a hole through the blade, so I went online for some advice. There was a posting about "spot annealing" using a blunt piece of steel in a drill... so I tried it with a short piece of 1/4" drill rod. The rod turned blue, and the blade was barely scratched. Attempting to drill it, as was suggested in the posting, just resulted in another drill bit for my scrap pile.
So, I decided to try the torch.... seemed like a good idea at the time - famous last words. Actually, it wasn't that bad. But I digress... I don't have a great torch setup yet, just a barely-adequate little oxy-MAPP set that's insanely expensive to keep filled with O2. But it worked... it was like cutting stainless steel... it just sort of "blooped" away from the place I was cutting, but I managed to get a hole through the thing.
Figuring there must have been a pretty good temper on the piece before I started, I doused the red-hot end of the blade it in a pot of water I had waiting for the purpose.
Great, all good... on to the saw. But wait! What's that "crackling" I hear? The blade shouldn't be making those noises.....
So, I gave it a bit of a flex - SNAP [insert explicative here].
Anyone want to tell me where I went wrong here? How would you put a hole through a pretty hefty hacksaw blade? ???
-Sparky
-Sparky
