James A. Lee
- Jan 17, 2009
- 10
- 0
I hope some knowledgeable soul out there can clear this one up for me...I've researched this for months until I'm crosseyed and blue in the face and still have no definitive answer. How in H*** do you go about making a master cam??
Gene Switzer in his design for a grinder glosses over the question with hardly a mention. except, "Make the master cam lobe four or five times larger that the lobes on the finished camshaft". (To me, that sounds as though you make it the exact shape as the finished cams, merely scaled up. that and sounds sensible to me) "The machine will reduce it in grinding.' (I am assuming that means you draw the master to a known larger scale, and grind to the needed final dimension.)
Ken Hurst says, "Making the masters is easy. I used aluminum plate, used a belt sander to shape the lobes and hand worked flanks and crowns. With good layout tools it doesn't take long." Oh! That's helpful!
In SIC, Don Bell says, "Master cam design is not a scaling up exercise. It is not an issue of adding the desired rise to the cam's base diameter. It is an adding activity".
WHAT??!! Bell shows a normal-looking cam together with his master, which is a very slightly flattened circle, goes on with the simple arithmetic used to derive the shape and then tells me, "A small defect on the master cam is magnified 12 times on the desired cam". That really blows my mind!! The concluding statement is, "Happy master cam designing".
And the 21st Issue of MEB, in the first part of a cam grinding article, the author shows the same oddly-shaped master, sort of a pumpkin-like thing which in some occult fashion results in a nicely shaped cam. using a rocker grinder.
OK, it's easy to see that I am good and confused by a lot of (to me at least) apparently contradictory info, and am really IGNORANT. I ADMIT IT, GO AHEAD AND DUMP ON ME ALL YOU WANT...I can take it!. But please,somebody, help me out here! I'm going bonkers!
Many, many thanks in advance. (And apologies to whomever I may have unjustly maligned)
Jim
Jim
