Lakc
Boxxer twin prototype
Having finally worked up the courage to start a build thread, and finding the spare time, I offer this up to our community. I cant promise any great contributions to the art, only the hope that some might find some things here useful. We learn from our mistakes, and I have made many so far, with no reason to believe that will change, as I hopefully complete this project. If your capable of learning from the mistakes of others, I should be able to teach you a whole lot! Some folks have spoke of having a preference for showing a build warts and all. I can say this build has been mostly warts. My hope for this first prototype is simply to make noise, not necessarily look pretty. It should be a rather simple build, we can work the warts out on the next one with experiance.
This engine design started approx 14 months ago, mostly as an exercise in CAD drawing. Unfortunate circumstances forced me to put it away, and almost a full year later I was able to work on it again. It is almost entirely of my own design. Some of you may recognise the cylinder head resembles the Edwards radial engine. The reason behind that is in my research to eventually build the Edwards, I was not entirely satisfied with the cylinder head drawings. This engine is partially the result of my desire to test my design on a simpler engine. Of course, one opportunity seems to breed another. In that respect, I utilized this opportunity to add a few "firsts" to my list, gearcutting, alloy steel crankshaft, pressurized oiling system, oil pump, and bronze bearings. The drawings are still slightly unfinished, mostly just I's to be dotted and such, but I am confident enough in its viability to forge ahead.
Bogs recently commented in another thread about patience. I fully admit that is a quality I lack, and hope to improve upon in this hobby. Many things conspire against me in this respect, leaving me precious little time to devote to my projects. The addiction to the good feelings that come from making progress, keep pushing me to do more in less time. Often this leads to disaster, and the proverbial scrap bin, or going back to "change the prints to match". Occasionally, it leads to efficiency. For the benefit of our impressionable readers, do not emulate my faults, just try to learn from them. I am guilty of starting a way more complicated project then this, and not finishing it. As such, with a few types of parts, this is not my first rodeo as they say, but the spectre of an unfinished project in my past has become a haunting one. I am hoping that this forum could provide a service to me by kicking me in the rear if I begin to slack off. I have a full time job, house, and a family, so my goal would be to get some kind of updates done each week.
Prequal
There is somewhat of a prequal, and you can read the thread in the casting forum here http://www.homemodelenginemachinist.com/index.php?topic=10845.0
The actual sequence of events does not start with the castings, but it fits along as a seperate side project if you will. For those of you who are turned off at the prospect of doing your own casting work, you do not need to worry. This engine can easily be built from barstock, and the maximum thickness of the case is only 1". I am sure some people would even consider barstock easier then the casting route. There have been times I would be inclined to agree with that sentiment, but I would like to make several of these, so the form work should pay off.
Gearcutting
The first order of the feasibility study would be cutting the gears. Revisiting the drawings a year after I first drew the engine basics, I had to reverse engineer the dimensions to determine what the gears specifications were. There is good news and bad news here. The good news is I picked simple tooth counts to index, 18 and 36 tooth. This ensured even my lowly enco cheapie 5c spindex would work. The bad news, aside from my mislaying the pictures, is to obtain the required .94 inch spacing it required 29dp gears. Good luck finding them commercially. That may have been a subtle nudge to myself to force my hand at the hob method of gear generation. Whatever the forgotten reasoning, the hob and gears were quite simple to make. Once I had the gears, I knew I had to build the engine.
I will include a write-up on the gears and hob once the pictures have been found. Edit Pics found, a few of them at least, down a few posts.
Crankshaft
Our story now picks up in early September. The most trying part of any engine build to me is the crankshaft, so I start with that first. We begin by chopping off a length of 1" 4140 steel from McMaster-Carr.
Chucked into the 3 jaw, I used a dial indicator and plastic hammer to center it as best as possible before attacking it with the center drill. The part was flipped over and centering was repeated on the other side. I always seem to have great patience at the beginning of the project. I suppose it helps when you havent made your first mistake yet.
Once the centers are picked up we move over to layout and scribe lines parallel on each end of the bar.
Over to the mill, the line was picked up with the wiggler and adjusted parallel to the vise jaws. Center was found, two more centers added for the crankpins. At this point I had a change of plans. I milled a 5/16x5/16 slot parallel to the centers to assist in keeping the alignment when I flipped the bar over for the other side centers. A 5/16 square toolbit worked admirably in this function.
Second verse was pretty much same as the first, flipped over, we had centers in each end of the bar in the appropriate places.
Time to move back to the lathe, centers in place, we began making mistakes I mean learning right away. Mistake one was thinking regular steel tooling would cut this alloy crank. Look at this horrible finish.
Once I switched to carbide tooling things got noticibly better, when I started using coolant/lube I was achieving good finishes again. I got lazy with cutting brass and aluminum, this was some tough stuff. 4140 comes in a leaded version, 4140L, which may make this part easier. With carbide and coolant/lube (astrocut2000) it was a good exercise.
The journals were .25 wide. I found the best way to attack this was with a .25 square soldered bit head on. There was some wandering of the bit at first, but as I progressively tightened and retightened every part of the holder, tailstock, and crossslide this eventually went away. If you have ever done this, you know the tedium involved in hearing the thunk of the bit taking its offset cut, and gently moving the bit forward in time to the revolution. I spun it up rather fast and took approx .003 cuts with each thunk, developing a rythum with the machine. This shot is the first journal finished, you can see the layout lines for the remainder of the cuts. All measuring was done with a dial indicator, the layout was for a visual doublecheck.
Second journal went much smoother and quicker. Plunge straight in, no real stopping. Lathe speed was kept higher as the diameter decreased. Look at all the .003x.250 shavings in the first pic.
Now is the point where 4140 really started to pay off. Under tight load between centers, I only measured about .oo4 spring in the journal gaps, and that was reefed down much tighter then it needed to be. This stuff is strong! Here is a left hand positive rake soldered carbide bit taking out the center marks.
Starting to look like a crankshaft, the nose gets a taper down to a 1/4-28 thread.
Thats about a good place to stop for now, more coming soon, lotta pics to rearrange and find. In a few more days, given the time, we will be caught up in real time.
