deadin said:MB,
Great post on valves!!
Im in the process of a build of one of the Upshur Farm engines and have just reached the valve/valve seat part. Ive been following Brians build of the Kerzel and the problems hes had with the valves and then reading your post, Im beginning to wonder if Ive jumped ahead of my skill level. (Way ahead!)
I do have a question . Why all of the effort in making the seat ream when the seat is aluminum and the valve itself is steel? I would think that you could cut a perfect seat and then when using valve grinding compound for the final seating, you would basically destroy the aluminum seat and it would take on any flaws in the steel valve itself. Why not just start with the actual valve and use it to cut the seat?
(Or am I thinking too simply?)
Dean
I don't know anything about cutting valve seats yet, but I agree 101% with the above quote from MB!The only way to progress into a higher skill level, is to take on more than you think you can handle at the present level.
chads said:The head on my engine is cast iron. Could I ream the valve steam hole, leave everything where it is and place a counter sink bit in the chuck. I'm not sure if that would be centered enough.
Any thoughts on this?
Don
chads said:I havent reached the point yet where I am working on the head but pretty close. I am always thinking one step ahead. I like the idea of making a seat cutting tool but also thought the countersink might be an option. Being that I only have one head, I need to choose the best option. Apparently there is no magic answer to this question ???
