chillybilly
- Nov 29, 2008
- 217
- 0
Well work is underway ,making the bits that my material stocks will allow as this one takes some big lumps !!!!!!
Made the rod from 2 seperate bits then machined between centres then onto the mill for the remaining ops,using bearings i got around the shop where i can to keep costs down , Cut the large dia for the crank from a piece of 5" steel bar by hand as the lump i have is too small for any of the power saws i have come across ,hour and a hlf with a new blade ,Knackering !!!!! joined the web to the shaft then machined all surfaces between centres then transfered to the soft jaws for the facing ops across the webs ,milled the connecting pin hole before i joined the 2 pieces ,experince eh !!! Need to mark out the crank webs then get them milled and then the next bit ............................... 8)
