can anyone tell me if it's possiable to get a nice surface finish from using a small fine stone normally used on a hand drill, but mounted on a mini mill since I don't have a surface grinder-thank you
it might work but usually with any precision grinding the surface finish is a bit dependent on dressing the wheel this trues it and smooths the surface of the stone.
thank you for the advise will any fine cup wheel stone work, and does anyone know where can I fine a cup grinding big enough to fit my Mini mill without damageing the the machine
