vederstein
Must do dumb things....
- Feb 26, 2011
- 921
- 746
I'm in the process of building a Webster and I've reached the point of the timing gears.
I went to Stock Drive Components and the 48 tooth gear is out of stock.
So what the hell, I figured I might as well learn a new skill and cut my own gears. Therefore I've been doing some research and now have some knowledge about involute gear cutters (pressure angle, depth of cut, why cutters come in sets of eight, etc.)
Finding a set of 14.5 deg x 32DP gear cutters for a "reasonable" price is a pain. I have issues paying $700 for a set of cutters to make two gears.
I did find a Hong Kong company (CTC tools) that sells involute gear cutters (about $100 for the set of 8 cutters), but with a metric nomenclature I'm not familiar.
So now the questions:
1. Is CTC tools a decent company and will they ship to the USA?
My research shows where DP is teeth per inch (32dp = 32 teeth per inch) the metric gear module is teeth per millimeter. Therfore to convert DP to Metric Module, divide the DP by 25.4:So the closest MM I found to a 32DP is a 1.25MM. (32DP = MM 1.259). It's 0.8% off from exact.
2. Is my math correct?
3. Is this close enough to work?
Thanks in advance.
...Ved.
MM = DP / 25.4
Thanks in advance.
...Ved.
