shred said:A while ago I ran across a Colin Binnie article on making the little drills and using them to drill gas jets, but I seem to have lost the link.
Another alternative is to take something like a #80 hole and swage it down smaller around a bit of thin wire, then pull out the wire.
That's what the cheap pencil-torches do I think-- the "Jet" is just a piece of punched foil.mklotz said:I can vaguely remember reading somewhere about making extremely small holes by using a needle to punch holes in very thin sheet metal. (The application may have been pinhole cameras but it's all very hazy.) The hole size was controlled by the depth of penetration of the needle. I'm wondering if the idea could be adapted to this application.
Here's the relevant bit. I'm not sure it's a recommended way, but it's an option.cfellows said:I think I'd need a magic wand to do something like that, Shred. :big:
GailInNM said:To drill, everything must be lined up very close and the drill run at high speed. I made a few and ran the drill at 17000 RPM. Keep the depth of the jet hole down to about 0.010 to 0.015 max inch so you don't have to drill very far.
