black85vette
- Jan 18, 2009
- 1,084
- 24
I am off on a new adventure. Bit off a big chunk this time. Looking at a box full of parts and the first thing that strikes me is how different this is than anything else I have done. Up to this point I was feeling pretty comfortable thinking through a sequence of operations that will give me good reference points in an order that makes sense and ends up with parts that line up, are square and concentric. Now I am looking at parts with ZERO finished surfaces. None of the sides are square or parallel. Also became comfortable with trashing a part when I screwed up and just making another one. Oh no, not now! Now I get ONE shot at getting it right.
Castings are from Cole's Power Models. Since this is my first casting set I can't give a comparison to others. All the parts appear to be fine. The plans are a couple of generations old copies. Still readable and I can always check a mating part to verify a dimension if necessary. Had a duplicate set made for use in the shop and "just in case".
Should be interesting. I plan on starting with the crosshead guide. Looks to be one of the more complicated and critical parts to get right. I will need to order or fabricate a boring bar. Nothing I have is nearly long enough. Then to the heads and cylinder since all of that has to line up.
In the mean time. I have plenty of flashing to remove and clean up to get done.
Expect a bunch of questions from me since I have no clue what I am doing. First question; where to start on the cross head guide? Any suggestions on the setup and order?
