Wagner1975
- Nov 11, 2009
- 13
- 0
I guess one can never have enough tools, and since the misses are not gonna let me buy more I decided to try my hand at making a flycutter, and then use that to make a rear toolpost for a parting tool. Didn't take many pictures, but here are some ...
Turned the flycutter from one piece of 40mm silver steel, to fit my 16mm ER25 collet. Then cut a 10mm slot in the bottom to fit a 10mm tool, and then tapped 3 M5 holes for grub screws. I silversoldered a piece of tungsten into a slot I cut into a 10mm piece of keysteel to use as the cutter. Not perfect :big: but it work, as you can see in the next pics ...
This is the base for the rear toolpost and the T-nuts I made for the Myford.
... and here is the parting tool that I wanna use, and the block that I'm gonna use to mount it in.
I cut with a dovetail cutter until the parting blade was at the correct height, and then made a top to clamp it tight!
And that's it finished and ready to make some chips! ;D
Dialed it in with a DTI and it cut through brass like butter
