Faceplate help
series60
So I have had my lathe for a while (grizzly 7x12) and I don't have a 4 jaw chuck. Was curious if anyone could enlighten me on the setup and use of the faceplate like fastening work to it. I want to be able to machine square stock with my lathe. Thanks for helping a kinda newb...
Get some angle, steel or al, drill and tap screws or all thread between and bolt to faceplate. Squeeze the square between the angles like a vise. Just one way. Use bolts,clamps whatever you have. Dave Gingery's books, 2 and 6 esp, have a lot on making your own clamping hardware for the faceplate. He uses castings but bar, plate etc could be easily substituted.
Make a nice lex an shield for in front of the lathe, bolt something up and try it. If it doesn't work try something else. It's a learning process.
Thanks cwelkie, I had lost track of Halls site.
The first accessory for a lathe should be a 4 jaw chuck. Then learn to quickly center your work. When the piece has to be concentric over a multiple grabs, a 4 jaw is the only way to go. Then there is square, polygon whatever, get and use the 4 jaw your work will expand.
Minor quibble here. A dead center in a 3-jaw chuck or faceplate along with lathe dogs is as accurate across multiple chucking. Of course this requires the other end to be supported by a live center in the tailstock and not removing the dead center.
Still, you'll need a 4-jaw eventually.
