black85vette
- Jan 18, 2009
- 1,084
- 24
I had read a number of posts mentioning the McCabe Runner as a good first build so I went over and had a look. Liked some things and didn't like some things so I thought I would take the concept but run it through the EZ engine process. First was the valve. The Runner uses a piston which has a drawback. During exhaust the engine has to push against the full force of the air pressure
In staying with the original concept I kept the materials to a minimum, tools to a minimum and used fairly simple machining. I used .75" square aluminum stock for the cylinder/valve block, the upright for the flywheel/shaft, and the mount for the bell crank. It can be built using only 4-40 screws so you just need one tap. The valve and the flywheel shaft are .25" so a reamer for that and a .5" for the piston is all you need.
I am just getting through the initial proof of concept and just have working drawings (slightly better than COC but not by much). ;D It runs fine and I have taken it down to about 3-4lbs. I have already got it to run on lung power with just a minimum run in time.
Not much in the way of build pictures because there is not much to it.
