Edwards Radial5 converted to metric
Discussion in 'A Work In Progress' started by Michael Rosenbauer, Nov 13, 2019.
  1. Nov 13, 2019 #1
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Laith operator, Milling Machine operator, cnc op
    Germany
    Introducion:
    I found the Plan for the Edwards Radial 5 at "CRABCAD" the plan was "provided" as open cource by Robert Sigler.
    My decision was to convert the drawings to metric dimensions draw them with DesignCAD and machine it.
    Some drawings are modified, because I feel not convenient with Mr. Siglers solutions.
    When I draw the plan I was easy convicted to modify my small mill Optimum BF20 to a CNC version.
    Some of the parts are not realy able to realise with a conventional mill for example the cam disc.
    I started with the cam housing, and then with the crank housing.
    Foketry and minh-thanh like this.
  2. Nov 13, 2019 #2
    josodl1953
    josodl1953
    josodl1953
    Apr 24, 2016
    107
    79
    Gender:
    Male
    Occupation:
    Retired
    Rotterdam, the Netherlands
    Looks nice! I made my Edwards camring without the help of CNC and it was a hell of a job.
    Are you making two engines?
    Jos
  3. Nov 13, 2019 #3
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    Hello Jos,
    thanks ! Yes I make two . One to sell cheap, just for the material´s at the next project.
    I sell the better one ;-).
    Can you explain how you machine a cam?
    Did you build it imperial ?
    Where did you buy the gears?
    I would appreciate if you can help with an adress
  4. Nov 13, 2019 #4
    josodl1953
    josodl1953
    josodl1953
    Apr 24, 2016
    107
    79
    Gender:
    Male
    Occupation:
    Retired
    Hallo Michael,
    I made a dividing disc with 360 holes and used it to mill each cam lobe according the lift chart that is supplied with the Edwards drawings. It is fully explained in the thread about my Edwards radial 5 build. Because it wat the most difficult part, it was the first part I made. If this didn't work, there was no point in proceeding with other parts. Because of this, you will find the post on this subject in the beginning of the thread.
    About gears: the Mädler company in your home country offers a vast range of metric size gears so I think you don't have to use imperial sizes.
    Grüsse aus Holland,
    Jos
    diegolopez likes this.
  5. Nov 14, 2019 #5
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    Hello Jos,
    yes I could find anything needed by Mädler.
    I watched your tread yesterday and I am very impressed of your craftsmanship.
  6. Dec 3, 2019 #6
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    I make some progress
    10 Zylinder completed. 27.00mm bore and beginning with the Cylinder heads.
    I made 2 tools. One for the Cylinder finalisation on the laith.
    the second tool is for fixatation of the cylinderhead. You can find it in the vice;)
    I started today with the cylinderheads. I hope I finish them end of next week.
    The CNC was also incharged but it was a little fail, I converted the bearing bore up to 14,25 but the bearings I will use have a 14mm outer diameter. :rolleyes:
    So I know now the CNC can make it:D
    minh-thanh and diegolopez like this.
  7. Dec 5, 2019 #7
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    Just want to know the dimentions:rolleyes:
    Foketry likes this.
  8. Dec 6, 2019 #8
    josodl1953
    josodl1953
    josodl1953
    Apr 24, 2016
    107
    79
    Gender:
    Male
    Occupation:
    Retired
    Hi Michael,
    Are you using the original size 4-40 cylinder bolts or M3?
    Jos
  9. Dec 8, 2019 #9
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    Sorry Jos for the late answer,
    I converted the plan to metric and using metric sizes. So I am using M3
  10. Dec 9, 2019 #10
    necchiom
    necchiom
    necchiom
    Jan 6, 2009
    91
    14
    Impressive. Can U share the metric drawings?
  11. Dec 9, 2019 #11
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    I can, but in what kind of file type
    I made (draw) them with DesignCAD
  12. Dec 9, 2019 #12
    necchiom
    necchiom
    necchiom
    Jan 6, 2009
    91
    14
    PDF or DXF woud be great!
  13. Dec 13, 2019 #13
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    Sorry necchiom
    I am ill at the time.
    I will investigate if my program convert them in a god manner.
  14. Dec 13, 2019 #14
    minh-thanh
    minh-thanh
    minh-thanh
    Dec 29, 2016
    538
    248
    Gender:
    Male
    Viet Nam
    Hi Michael !
    free plans or sell ?
  15. Dec 14, 2019 #15
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    For free!:)
    Robert Sigler set it for free, so do I.
    minh-thanh likes this.
  16. Dec 14, 2019 #16
    necchiom
    necchiom
    necchiom
    Jan 6, 2009
    91
    14
    Thanks Michael!
  17. Dec 15, 2019 #17
    petertha
    petertha
    petertha
    Well-Known Member HMEM Supporter
    Jun 24, 2010
    1,424
    270
    Hi Michael, just curious. Did you redesign the cam ring & planetary gear assembly dimensions around metric gears or did you stay with original imperial gears?
  18. Dec 15, 2019 #18
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    Hey Peter nice to hear from you.:)
    First I wanted to stay with the imperial gears, but it is so easy to get the same gear reduction (number of teeth) at the German supplier and I didnt get the imperial easy in germany.
    The out side teeth gear wheels I made myself. The inside is about 40€ each. Thats Ok.
    The distances are within a few tenth.
    So it is easy to align.
  19. Dec 15, 2019 #19
    petertha
    petertha
    petertha
    Jun 24, 2010
    1,424
    270
    Ah, that makes sense. So I assume you selected module-1, crankshaft = 18 tooth, idler-1 = 18 tooth, idler-2 = 12 tooth, ring = 48 tooth?
    Look forward to your building pics!
  20. Dec 16, 2019 #20
    Michael Rosenbauer
    Michael Rosenbauer
    Michael Rosenbauer
    Active Member
    Nov 11, 2019
    42
    10
    Gender:
    Male
    Occupation:
    Germany
    You are right!
    Pictures comming soon!;)
Draft saved Draft deleted
Share This Page
