Mosey
OK, what is the trick to setting up your vise on the mill table so that it is (almost) aligned without using the test indicator?
Do you have tabs on the underside that align with the table slots?
And, even dumber, do you set it up longways on the x axis, or across the table? Do you ever run out of travel and have to reset the vise in the middle of making a piece?
And, even dumber yet, do you have the ram set all the way forward, at the back, or in the middle? Again, have you ever run out of travel in the middle of a piece?
