It is so fun to have a home machine shop. You run into an issue, you design a few parts on the computer, go out to the workshop and make those parts, and viola, problem solved.
I have a 3D printer and I like to print using HIP filament as support. That is, I use ABS for the main part, then have a second extruder that prints HIP for the support structure. After the print is complete, the HIP separates easily and you can print most anything that has overhangs or large bridges.
But my dual extruder setup has to have the two extruders exactly the same height off the bed. The extruders alternate laying down ABS, then HIP, but they are both hot. The extruder that is not in use drags through the material the other is printing and this impacts the look of the finished part. Sooooo, I thought why not make a mechanism that lifts the extruder that is not in use while the other prints.
I drew up a design on the computer. I put the dual extruder unit on ball bearings, then use a servo to rotate the print head assembly just a little raising the unused extruder about 2mm. I made some steel standoffs and strategically placed some magnets so the print head "snaps" back and forth into position, locked rock steady.
I 3D printed a couple of parts, made a few on the lathe, then cut a couple aluminum parts out on the mill. This is my proto type and is working surprisingly well. As can be seen there is no interference between the two print heads and the white and orange filaments are being laid down cleanly.
Any two filaments can be used, you could make a part in white, and insert black lettering for example.
If you look closely you can see the servo and the linkage to rotate the print head assembly. The servo is the blue thing with the grey, red and orange wires coming out of it. The servo arm with the linkage attached is just above it.
It is so fun to have a home machine shop. If you can dream it, you have make it.
