DRO instructions
geoff
Active Member
Hi
I have Warco DRO with attached readouts fitted to my Mill and wonderfull as they are to use there are some functions i do not understand, as there were no instructions and Warco don`t supply any. As you can see in my pic they read in MM and inch with fractions which is very usefull and there is also a Absolute button and a set button which i`m not sure how to use. Has anyone else got this model or a similar one.
Geoff
rudydubya said:
Geoff, your readouts look identical to the iGaging units I got from Grizzly. Mine came with the instructions shown here: http://eacmedia.net/manuals/IGAGING/424-0160.pdf
Hope this helps.
Rudy
These Asian manuals are usually wrought with bad spelling but I believe they hit on something in this pdf when they refer to milling machines, etc. as "manchinery".
I got the same ones. I consider the fractions useless however. The absolute is like a reference on a CNC. Kinda useless too IMHO. other than that they work reasonably well. Mine show about .001 per inch error according to my Jo blocks.
Many thanks guys for your quick response, I don`t know why Warco did`nt include these instructions. I still think they are a great addition to working accurately especially when you have lots of holes to set out.
geoff
Just a quick heads-up Geoff - I have fitted these on my Warco mill and they work very well. Only thing is to avoid having to replace the batteries often, I find that when not being used, if I "unplug" the leads that actually go into each display unit (not just switch them off using the on/off button) then they last many, many months. If I forget to do this then a couple of weeks sees me fitting new cells.... ;D
All the best, A
