DIY Reamers
shred
With the discussion of shop made reamers, I found this in my files. I think it's from Colin Binnie-- if anybody has proper attribution, let me know. I've seen the 'type 1' called a 'toolmaker's reamer' elsewhere.
Thanks Shred, duly noted and filed away for use.
Ron
Thanks ! Really helped today when I needed a 1/8" reamer
This method works very well. Many times I've used it.
Take music wire the size you need and grind it at about 30 deg. on the bench grinder, drill a few thousands under and then use this new reamer. It will usually be within about a half over. It is prooven. usually works with soft metals as aluminum and brass, only a couple of times used it with steel. Excellent with number sizes.
is there a limit as to how big this method will work ?
I've made them up to 1/2" with no troubles
The aren't for hogging mind you, but they will bring the hole to size.
Dave, At 1/2" how much under did you make the hole ?
Hi BMeyers,
Sorry for the delay.....
.002 - .005......this tool was never made for hogging!
Here's the procedure.
Drill undersize.
Bore to .002-.005 undersize. This takes any run-out out. If you don't do this, the reamer will follow the hole and your finished hole will run-out
Finish with the reamer at slow speed and steady feed. and lubricate as required for the material.
Once I'm through, I stop the lathe. THEN I retract the tool with the work stopped as I worry it may cut on the way out due to chips getting wedged behind the back of the tool, forcing the cutting edge into the work.
Dave,
thanks, I made a 12 mm one today. drilled 15/32" then reamed hole in the mill. holed ended up at .472" I am pleased.
I have numerous broken bits of carbide burrs from my foredom (y'know, rotary tool cum die grinder that would eat a dremel for an appetizer before hogging into some cast iron and finishing up with some fine polishing and detailing).
Anyway I've brazed various sizes of these (i've got everything from some itsy pcb cnc cutters to 6mm and 10mm burrs) onto some drill rods with a suitable notch cut-out at the end so as to leave just the teeth sticking out with some clearance (be sure to orient the burr so the teeth incline up and back, clockwise as it were).
These babies will rip a hole wide open super fast in just about any material (multiple cutting points), they aren't fussy about their orientation, and will leave a lovely smooth finish when you ease off for the last few passes. Only tricky bit sometimes is just getting that damn bit of burr to stay in place as you braze the bugger ;)
Perhaps you can post th_wwp a picture of one of the tools you have made. Maybe I'm just slow, but I am having trouble visualizing what you have done.
SAM
