Heater cartridges from 3d printers can heat up the aluminium of the engine, if you are able to accomodate a heater block or blind hole.
You get around 40 W out of one. Diameter 6mm and length 20 mm.
No idea if that is useful information, or if i miss the point. At least it is not very expensive (provided you have a power supply already).
Greetings.
Seeing this reference to 3d printer heaters, I was poking around some sites and noticed numerous sources for hardened steel printer nozzles down to 0.2mm. Very inexpensive. Seems like they might be suitable for injector tips.
![HardenedSteelPrinterNozzles.png HardenedSteelPrinterNozzles.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/103/103334-HardenedSteelPrinterNozzles.png)
