I have been going over in my head the past week or so, the various methods to cut a shallow concave into the surface of an engine base. The depth of said cut would be about .125" and the width would be approximately 1.00". Now, I have considered mounting the piece to an angle plate that is secured to the lathe carriage and then using a boring bar of sorts mounted between the centers to achieve the final result, but, my question is, what if I used a fly cutter in the mill and set the angle of the head over so that the cutter could sweep a given arc to create the depression. Have any of you gentlemen performed this type of procedure? I don't know if I have made myself too clear here. The ultimate goal is to cut a dished trough if you would, the length of a flat base made from 6061 Aluminum. I'm just machining in my head at this time and am open for suggestions. Thanks.
BC1
Jim
BC1
Jim
