Critique my setup
Im making plates for a finger brake I am working on and I am not quite sure of this setup. Could any of the more experienced members give me a heads up if anything looks wrong? I want to put a 52-degree (exact angle within a degree is not critical) bevel on the fingerplates and the only bit I have is a 60-degree dovetail. I have an alum extrusion with a flange on one side that I mounted as a stop for the one side of the piece. I had to elevate it with 123 blocks to get a good height for the bit, and indicated the rear flange to within a thou. I then used a parallel to raise the front of the piece to get my proper angle for the cut. To keep the parallel from flopping about I ran screws with large washers into the extrusion. The holds down clamps are the items that are a bit of a concern, because they are on an angle. I am only taking light cuts and all seems well, but I thought it might be a good idea to get some feedback on it. Please be brutal, I am a retired Tin Knocker and have no formal machine training, only what I have picked up on the forum, but I do want to learn.
One other thing, the chips I am getting are superfine, almost like dust. I am running a light cut (.030) fairly high spindle speed and a slow feed rate. Is that typical?
Thanks,
Bill
Thanks,
Bill
