cleaning off excess silver solder
firebird
Hi
Iprobably know the answer to this question but just in case I have missed something I'll ask. I had to re-solder the top of my current boiler build due to a small leak. Unfortunately the solder ran everywhere as can be seen in this shot.
Armed with small files/emery/wet & dry I am trying to clean up the top plate. Not easy with the bushes and funnel in the way. Is this the only way or are there any tips I should know about, apart from be more careful next time. ::) ::) ::) ::)
Rich
Hmmm ... my only suggestion would be small files/emery/wet & dry
Hi Tel
Do I need elbow grease????? ;D ;D ;D
Rich
don't know if it would work
I use a dremil drill with a rubber pad (like the old ink pen erasers) to remove casting lines in aluminium its not as abrasive as grinding wheels
Wayne
Rich,
Go over to your favourite local supplier, they have on special offer some 1/8" shanked 120 grit flapwheels. For use in your mini drill.
http://www.arceurotrade.co.uk/Catalogue/Clearance-Items
They should be able to get rid of the excess fairly quickly. Then finish off with some elbow grease once the thick stuff is out of the way.
At 50p each, it is worth buying a few in. I would go for the larger size, as they soon become the smaller sized ones anyway. I bought a load of the 1/4" shank ones, and they are very good quality.
Just a hint about next time you get carried away with the silver solder. Get a pencil and draw around the part you are soldering, the silver solder shouldn't flow past the graphite or lead barrier, Tippex works just as well.
Blogs
Hi
Thanks all
Found some elbow grease. I'll nip into arc and get some of those flap wheels. Wayne, I have some rubber ends, do you use them dry??
Rich
I've used a micro-blaster and either x-fine glass beads (takes a while) or 220 grit AlOx (faster, but can remove base metal). You've gotta be careful not to intrude on the integrity of the boiler.
Yes I do use them dry
it might be worth a try never used them on solder before but worth a try
Wayne
Hi
Picked up one of these little spiral emery thingies for the dremel type tool
It made quick work of removing most of the excess solder. Then with a bit of wet and dry it looks much better. There are still some scratch marks but overall its a great improvement. I must be more careful when soldering.
Rich
If I have to keep solder off of an area, I find that a carpenters lead pencil works well to keep the solder from spreading and sticking. The wide soft flat lead makes fast work of covering an area. The solder will not stick to it, and it cleans up real quick when you are done.
Dale
Took the words right out of my mouth/keyboard. ;D ;D
Hi
Thanks Helder and Dale thats a good tip.
Rich
Rich,
You can try one of those blender disks 2" (like a scotch brite pads) loop and hook type attachment to go into your dremel then place a pad on...away you go. It's not as aggressive as one of your emery thingy.
I used them when we had to weld a band saw with a crack...I would use it to finnish the weld to within 1 thou of the plate thickness.
By the way, I like your build logs...well done!
Philly
Hey Rich
Did you try the rubber wheel I would be interested on how it worked
Wayne
Hi Wayne
No not yet. I'm going to try it next to see if it will remove the scratches I have put in with the emery thingy. I will be away on hols for the next 2 weeks so no more posts for a while.
Rich
