Carburetor
nfk
Bottom Member
Hi folks.
I where looking at cfellows carburetor drawings and i think i`m going to use the design for my engine. (thanks for the plans!)
The doubt i have is how much should i enlarge it...
The plans call for a throttle body of 1/8, and it won`t be enough for my application.
For a 14cc 2T boxer twin engine, what size should be ok?
Should i use another design instead?
Thanks for any help!
Norberto
Don't want to discourage you, but my carburetor design is pretty basic and I doubt it will give you the performance you want.
As far as size goes, Randall Cox built a 6 cyclinder, 1 inch bore x 1.5 inch stroke engine and his carburetor had a 1/8" venturi. It seemed plenty big enough to run the engine at a good clip. Randall's engine was featured in the first 2 issues of Model Engine Builder and was called the Open Column Six.
Chuck
Hi
Thanks for your reply.
I have the issue and was one of the first things i note about the size, but glow engines i have, use way bigger carburetors.
I have a few cox .35 and the venturi is 6mm wide :-\
I know venturi size is not linear with displacement, but i`m not sure about going with 1/8.
After assembling, i was amazed about the vacuum generated when the pistons go up, the small hole (3mm) i left where the reed valve and carburetor should go, makes you feel a resistance when turning the crankshaft. (enough to leave a mark on your finger!)
The engine probably won`t see any plain action, but i want it running the best i can. (i will build another with all the bugs fixed, i have a great model for it!).
I will build it with 1/4 and see what happens, i have a load of free materials for it. (nice history, i will tell later!)
Norberto
A two stroke will usually want a bigge venturi than a four stroke. RPM also makes a difference. A 2 stroke .35 engine running at 6,000 RPM pulls a lot more air than a 4 stroke running at 2000 RPM.
Chuck
stevehuckss396 said:
Why not build it with a 1/8 inch and increase if you have to. Might save you alot of work.
I built it yesterday using 1/8 and leaving some room to enlarge it. (Thanks for the tip!)
The good news is the engine started :)
The bad ones are that the reel valve is not working as expected or 1/8 is too small...
The valve is 10mm, it should be enough. I`m not sure about the membrane material, i`v used a piece of old x-ray acetate and i`m thinking it could be too thick for my application.
What would be your choice for it?
The engine started easily after priming, but after a few 'pops' it stall.
Repriming makes it to start again, but it stall again after a few pops.
Tonight i`m going to try a different valve material, and if it don`t work, i`m gona enlarge the carburetor to 6mm and try again ;)
I`ll add some pictures to my build thread later.
Thanks for your help!
Norberto
Your imidiate problem isn't the 1/8" venturi, but most likely the height of the fuel in regard to the needle on the carburator.
It sounds as it has a problem sucking the fuel up to carburator and this is a problem that increases with a bigger diameter venturi. That said - I'm sure that 3.175mm. venturi is very much on the small side for a 14cc two-stroke 5-7mm sounds about right - again, start with the smaller diameter.
Your valve material will give you problems when the engine gets hot enough to melt the plastic, but not for a few seconds of running or a minute or two.
Thanks, it`s the next thing to try tonight :)
What you recommend for valve material?
This won`t be my last reel valve ;)
The question of size depends on how much power the engine will be making. If the engine is just free running, the carb need not be large. If it has a load to pull, too small a carb will limit output power.
Greg
