- Dec 28, 2008
- 1,731
- 9
#1 After two days of cleaning and organizing my shop I'm happy and ready to start another build. The (before) picture below shows the sad condition of my bench work surface. The bar stock picture was the only one I could find showing the old surface. I would usually avoiding taking any close up photos of it for obvious reasons.
#2 The bench (after) eliminating some of the clutter and the application of a better 'Rubber Maid' work surface. Now it has a more inviting look and feel. On the left is my old grinder. When I run it anything on the bench that's not bolted down usually ends up on the floor. The access to it is also very difficult. The clean up yielded a smooth running grinder hidden and forgotten for years.
#3 The photo angle below was not possible in the past. At the bottom you can see a red lamp shade over a second work bench that was buried with boxes. The boxes were also in front of it, making access to the bench impossible.
#4 Below is the second work bench. The grinder was not seen by me for 15 years or more. My main bench is on the right and perpendicular to this bench.
#5 Milling the aluminum 'floor' plate to start off the build.
#6 I milled the 'base' and 'sub base' also from aluminum.
#7 That's all I got so far. Not much but its a start. Just like a journey that starts with the first few steps, an engine build starts with the first few parts. I number parts in progress for easy identification of the build model by the viewing audience. It's not for my benefit, I usually remember which engine I'm building. Usually... :big:
-MB
-MB
