#33 For today's post I built the crankshaft. The first step was to turn down stock that the three crank disc's would be cut from. I chose aluminum since a good supply of 1-1/2" round bar stock is on hand. I chucked it up in the lathe and center drilled for a tail stock live center due to its length. After machining the O.D. I drilled and reamed the central 1/4" hole all the way through and faced the end. I removed it from the chuck and cut off the larger 1-1/32 disc in the band saw. After returning the stock to the lathe the two smaller disc's were faced and then cut off with a parting tool. All three discs are faced on one side and will be faced from the other side to exact length after the crank pin holes are drilled.
The reason that I removed the stock from the chuck, and cut off the longer piece first, and in the band saw, was that I felt it was sticking out of chuck to far for parting off safely. I marked it first so that it could be returned to its exact position. I checked it for run- out with my dial indicator before proceeding with the facing and cut- off of the smaller discs.
#34 To accurately drill the crank pin holes through all three discs, a simple holding fixture would do the trick. After clamping a scrap block in the mill's vice, I faced it flat to insure that its face would be perpendicular to the mill's spindle axis. With the hand wheels zeroed out I drilled and reamed a 1/4" through hole. This will allow the disc's to be individually bolted "faced side" down to drill and ream all three disc's. After shifting the tables X axis .375" both thinner disc's were drilled and reamed. The thicker center disc was drilled and reamed last to insure accuracy. After its first hole was drilled and reamed, the table was shifted back to zero on the X axis, and then shifted .375" on the Y axis to drill its second hole in one set up. I used a precision .250" rod threaded on both end to accurately locate and hold down the work pieces during the drilling and reaming operations. The 90 degree offset on the crank throw has me scratching my head. I keep thinking that maybe I should have changed it to 180. Any one have any thoughts on this?
I guess that a four jaw chuck, along with a proper lay out of the hole locations would also do the trick, if I had one.
#35 The picture below shows the crank pin holes being drilled and reamed to the finished size. Afterward they were returned to the lathe for final facing and sizing.
#36 To assemble the crank I used a different sequence than the one that Elmer suggests. For step one I installed the main shaft into the larger center disc with Loc-tite and let it cure. In step two I added one out side disc and Loc-tited it to the center shaft only, and used the short crank pin for line up only, while spacing it away from the center disc with space blocks.
#37 After the Loc-tite cured on the first out side disc, the same procedure was followed on the second disc. In the picture below you can see that the crank pin is not in place an can be moved about freely while the second disc sets up. After all three discs cured and became one with the center shaft, the two crank pins were removed and installed with Loc-tite. The white smudge in the picture below is a piece of paper towel used to absorb excess Loc-tite on the center shaft. I didn't want my space blocks to become a permanent part of my crank shaft assembly. ;D
#38 The final but scary step is to hack saw out the center shaft between the crank throw webs. Its a good idea to protect the crank pins with several layers of tape or whatever is deemed appropriate during the sawing. On my first attempt of this type of crank shaft, the saw broke through and landed on the crank pin creating a unwanted cut.
I offset the crank to allow for a possible 1/2" wide flywheel on one side, while reducing the other side to a 1/8" protrusion out side of the bearing. With a light aluminum crank I might want to add a fly wheel. In the plan the shaft is centered and the protrusion on two sides seems a bit small for the addition of any thing other than a thin pulley.
After a little bit of filling to clean up the saw cut ends, the crank is masked and ready for paint.
Did you notice that I left out the expansion pins? I'm getting a little brave! :big:
-MB
