Looks like need to get the galvo off ...ho hum glad i checked
"According to the American Welding Society, Metal Fume Fever is an illness caused by exposure to zinc oxide, a chemical present in fumes from welding and brazing galvanized metal. The symptoms of metal fume fever are flu-like, including headache, nausea, fever, fatigue, and chills. Symptoms start several hours after exposure and last 6 to 24 hours, although total recovery might not be for 48 hours. High levels of exposure may cause metallic taste in mouth, dry and irritated throat, and coughing. Several hours after exposure, you may have a fever (lower than 102 degrees F, then chills before returning to normal). The OSHA standard for zinc oxide exposure is 5 miligrams per cubic meter of air averaged over an 8 hour work shift. NIOSH uses the same 5 mg per m3 (cubic meter), but suggests that it is permissible for 10 hours per day, or 40 hours per week. They further permit a STEL (short term exposure limit) of 10 mg/m3 averaged over a 15 minute period. There is no published information about long term effects of zinc oxide exposure. (American Welding Society. Safety and Health Fact Sheet No. 25) Even though there are no known long term effects, it doesn't make sense to expose yourself to zinc oxide and potentially suffer from Metal Fume Fever, because it's easy to prevent exposure. Brazing, as opposed to welding, produces fewer fumes because of the lower temperatures."
