BA and Whitworth thread depth calculations
bezalel2000
mklotz said:
If you look at a thread diagram, you'll see that the depth of thread (sharp crest to flat root), is given geometrically by:
D = [[3/8]/tan(30)] / n = K / n
where:
n = thread pitch in tpi
and the thread angle is assumed to be 60 degrees (as it is for American and metric threads).
Doing the math , K evaluates to 0.649519
Simple Question
What is the general formula for thread depth? :shrug:
Now I know, thanks to Merv's and Rick, that for 60o threads thread depth per pitch can be calculated from a constant k = 0.65
I can also extrapolate from major/minor diameter charts that for;
Whitworth k = 0.64 and for,
BA k = 0.60
So how do I calculate it. ???
I know I could look up the chart, but with advancing years an A4 sheet is just big enough to accommodate the formula where I might previously tabulated the whole chart. ;D
Thanks
Bez
Well, I usually just look it up but, as I understand it .....
Whitworth k = 0.64
means the depth of the thread is the pitch x .64....
so a 1/4" Whit thread has a 20 tpi thread - p = 0.050 ....
so that gives us .050 x .64 = .032
so depth of thread = 0.032"
Thanks Tel
What formula did you use to get 0.64 for 55o thread form?
and what do you use for the K of BA thread?
Bez
Whitworth
d =0.5p x cot 27.50 = 0.64037p (included angle = 550)
BA
p = pitch mm
H = V form height = 1.13634 x p (included angle = 47.50)
r = top and bottom radius = 0.18083 x p
h = depth = 0.60000 x p
Best Regards
Thanks Bob
I think its coming together now.
though I think there may be a typo in your formular, I can only get the numbers to work out right if I substitute 0.33 in place of 0.5
General formular for thread depth;
d = fp x cot(a) = K/n
where
d = depth
f = form factor UNC-metric = 3/8 5/16, Whitworth = 1/3, BA = 0.264
p = pitch
a = 1/2 inclued angle
n = Tpi
k = depth x p UNC-metric = 0.649519,0.5412658 Whitworth = 0.64037, BA = 0.6000
scratch.gif?
Oops, yes 1/3p is correct Old fingers and even older eyes ::)
Best Regards
I just pulled those out of your original post Bez,
BA k = 0.60
So how do I calculate it. Huh?
Didn't check them against anything.
The actual numbers are;
Whitworth (and BSF) d = Actual Depth = 0.640327 x P
Metric d = Actual Depth = 0.541266 x P
UN (coarse and fine) d = Actual Depth = 0.541266 x P
BA d = Actual Depth = 0.60000 x P
ME d = Actual Depth = 0.640327 x P
... might be worth getting tattooed on the inside of our eyelids!
tel, I think the above is for internal threads
external threads are 0.61343p
It has something to do with where the radii, (crests), versus the flats are on internal v external threads.
Makes you wonder who sits down and adds all this, to me, unnecessary complication. I mean at what tolerance do they change/reshape the wheel on a thread grinder or the roller on a thread roller??
Best Regards
You could be right mate, but the book I have doesn't distinguish between internal and external, just sez 0.541266 x P
You will notice, however, that this is the same figure given for metric threads and, given that they are both 60° threads that makes sense.
Lets have a look - depth for a 1/4" thread with my figure is 0.0270633
with your figure it's 0.0306715
... don't figure I"m gonna get in a fist fight over 0.003" on a coarse thread like that!
hay
look her http://www.britishfasteners.com/threads/unf.html ::)
Marcel
snip/snip
It would save counting sheep
0.61344p, and 0.54127P :eek:
Now theres 2 numbers I haven't seen before I thought we were using 0.649519 :wall: which was derived from 3/8*cot(30)
but 0.54127 = 5/16*cot(30)
0.61344P is depth of cut for the screw and
0.54127P is depth of cut for the nut
I think its time to drop the maths and get my Eyelids tatooed :big:
