Another Knucklehead, built via castings, as a Draw-Tech design, upscaled
Foketry
Modena (motor valley) Italy
After seeing the construction done by Mayhugh, I also decided to build this interesting engine in a slightly larger scale.
The pistons of my engine will be 36 mm instead of 1.063 inch (27mm) and everything else will consequently be increased by the same proportion.
I have followed and studied all of Terry's posts, whose technique and precision I admire and I hope to obtain a well-functioning engine like his.
I also asked Terry for some 3D drawings and he kindly provided me with some ,I started from these drawings
After the 18-cylinder Isotta Fraschini, I returned to simpler engines, just 2 cylinders, even if Terry writes that it is not that simple
To make aluminum castings the first step is the 3D drawing of the finished part, then I eliminate all the holes and machining, add the allowance in the milled or turned areas, add an increase that takes into account the aluminum shrinkage .
Finished right crankcase
drawing for casting mold
3D printed mold with parting powder
I generally paint the mold to obtain smoother surfaces but in this one I didn't paint
the sandblasted casting
