- May 3, 2011
- 410
- 67
i have some jobs coming up that could really do with a 4th axis. my cnc controller box is already geared up for a 4th and 5th axis, and with the advent of fusion 360 making its self free to all hobbyist (thanks Autodesk) it is now possible to run a 5 axis mill.
so i have been hitting the numbers to find out gearing between the stepper and the table. i know that normal rotary tables are 90:1 that would be great, but they do suffer from backlash. this can be made to a minimum but you will still have some. next option would be timing belt. problem with that is your now down to very low gear ratios e.g 6:1 other wise pulleys tend to get big. next is antibacklash worm drive. this will now put us back up to the 90:1 plus. and the last one is the harmonic drive. no backlash, high ratios....... not cheap.
it seems that the easiest option would be belts and pulleys. that then brings up the gear ratio. if you take the step of the motor, plus microstepping divide it all by 360 etc etc. and make the gearing 3.6:1 (20t:72t pulley) for each step you will get 0'3'0 deg. this works out well. but if your part has a 4"rad and you machined at 4" you would get a flat that is 0.12mm wide at each step. on an 8 inch part would this really be a problem? depending on space i could go to a 144 tooth pulley or up the micro step count.
as this one day will sit on top of a 5th axis both 4th and 5th should really have the same gearing and all sit in a compact design.
I have all the gear i need to build it now, as in steppers and controllers so it should be a quick build
thoughts??
thoughts??
