Hi guys,
Ive had a bit of experience with thread lock type anaerobic adhesives now I want to try a bearing retainer type, made locally in Sarf Efrica by Pratley. Pratley products are pretty good, over here we believe that Pratley epoxy is the only SA product to have gone to the Moon. How strong is a bearing retainer type glue? For instance, if one has a close fitting slip fit shaft glued in a pulley can one transmit usable torque, say the glued area is around 2 square inches? How do you eventually disassemble the glued joint, assuming that it holds?
Thanks,
Ant
Thanks,
Ant
