Alternative model engine fuel.
oneKone
Hi,
I figured out I'm allergic to pump fuel and methanol so I'm going to have to drop them as a fuel for model engines.
I was wondering if anyone knows of any systems where LPG or butane can be used as a fuel without leaking everywhere.
Chris
Have you tried the camping fuels such as Colemans, and the "green " ones like Aspen if you can get them down under. These are a good substitute for pump fuel but won't work as a replacement for methoanol fuels glow engines.
If you want to use LPG then you need a demand regulator that senses the vacuum in the carb as the engine sucks in air/fuel and opens then closes off for the remaining cycles.
Tip 3 on this page shows details of one, there was also a design in model engine builder mag
http://www.floridaame.org/HowTo2.htm
Hello Chris,
I routinely use Shellite.
Kerry from OZ
Cheers for both replys. @jasonb sorry I replied earlier but it didn't get posted.
I recently found out that I'm allergic to 2 stroke oil (mineral) so I can still use pump fuel luckily.
@KLG would you know if a different compression ratio is needed for shellite?
Chris
The Shellite is naptha based like the Colemans fuel and I have not found the need to alter any settings, this is mainly on hit and miss engines but my 4 stroke aero engines also run fine on it
Chris
Hello Chris,
Jason B is quite right regarding CR.
With low speed model engines the effective CR is usually a lot less than the calculated CR because of the closure point of the inlet valve.
Shellite has a few of the components of pump fuel(up to 30% n hexane) but minus the toxic components (benzine) and is much safer(toxic wise) than regular pump fuel. You will not damage anything trying the fuel and you will be using a much safer compound.
Kerry from OZ
