Kenny,
How much material do you need to remove?
Did you get a tapered guide sleeve with the reamer? It wouldn't be much of a job to make one up if not. It will guide the reamer in the hole from the back side.
The expansion reamers work ok as long as you don't try to force it. They really don't work too well for "scraping" cuts in a rough hole unless there are an odd number of flutes. Mine have six flutes and that makes them easy to adjust for size, but once they start to chatter it's hard to correct. They aren't any good for interrupted cuts either due to the straight flutes.
Make sure to keep them clean, brush off any chips before you adjust or the chips can get under the locking rings and seat and screw things up. I use sulphurized thread cutting oil on mine, other cutting fluids will work, just use something. Don't try to push the reamer through the hole too fast, let it cut. When you adjust size, don't measure just one flute, measure all and in more than one spot. If dirt got under the blades, that will show it.
Take your time and keep things clean, should be no problem.
Kevin
