1.5cc aero glow engine
topogigio
Italy
Hello !
I would like to show you the construction drawings of a scooter that I built years ago.
This is a 1.5 cc glow ignition model aircraft engine completely obtained without castings.
My prototype easily spins a 6x3.5 prop at around 15000 rpm.
I hope it stimulates someone to build another one.
Thes are the 3D pictures ...
And these are the 2D building drawings in metric ...
  • ALBERO APEX 1.5.pdf
  • ASSE APEX 1.5.pdf
  • ASSIEME APEX 1.5.pdf
  • BIELLA APEX 1.5.pdf
  • BRONZINA APEX 1.5.pdf
  • CAMICIA APEX 1.5.pdf
  • CARBURATORE APEX 1.5.pdf
  • CORPO APEX 1.5.pdf
  • CUSCINETTO APEX 1.5 6x15x5.pdf
  • DISCO APEX 1.5.pdf
Other 2D building drawings .....
  • GUARNIZIONE FLANGIA APEX 1.5.pdf
  • GRANO APEX 1.5.pdf
  • GUARNIZIONE CAMICIA APEX 1.5.pdf
  • GUARNIZIONE TESTA APEX 1.5.pdf
  • OGIVA APEX 1.5.pdf
  • PERNO APEX 1.5.pdf
  • PISTONE APEX 1.5.pdf
  • PORTA CANDELA APEX 1.5.pdf
And the last 2D drawings ....
  • PORTA ELICA APEX 1.5.pdf
  • RONDELLA APEX 1.5.pdf
  • SEDE DISCO APEX 1.5.pdf
  • TESTA APEX 1.5.pdf
  • SEDE ALBERO APEX 1.5.pdf
  • TIMING APEX 1.5.pdf
  • VITE 7 APEX 1.5.pdf
  • VITE 10 APEX 1.5.pdf
Hello !
Do you have any photo's of the finished engine or video of one running, that would be very interesting.
You're right Bazzer, I've attached some photos and a little video !
  • video.MOV
    19.7 MB
Very good, nice to see a little glow plug motor built and running. Will you fly the engine?
Not this one 1.5 cc , unfortunatlyI am not capable of flying a radio-controlled or control line model airplane .
But I flew another engine ( a 2.5 cc) on one of my control line model , but it was driven by a friend .
OK understand,
Thanks Buzzer it would be nice, I've tried several times controlline but unfortunately for my dizzy !
Last year in October I was in the UK on the Buckminster track for the closing event of the tethercars.... a fabulous place indeed!
I know those guys who do the tether cars well, Ollie Monk is a keen model engine tuner and makes a lot of parts.
Also did you see the F2 control line circle at Buckminster, that is very nice.
If you go again, drop me a line and I will come up to Buckminster.
