Hello all,
Vertical-One
1" bore x 1.5" stroke
Flywheel, 5.5" cast iron
Piston: Cast iron with cast iron ring
Cylinder: Steel
Ignition: CDI with Hall Sensor
Timing:
Ignition: 5 degree BTDC
EO: 40 degree BBDC
EC: 15 degree ATDC
IO: 10 degree BTDC
IC: 5 degree ABDC
[ame]http://www.youtube.com/watch?v=rQSRTw5B10Q[/ame]
This engine which I called it Vertical-One is completed.
I designed this from scratch and worked on it for about one year part time.
Here you can see the first video of this engine running with the initial setting and not much tuning. Since this video I have put over 2 hours of run time on this engine and everything is holding pretty well. The longest non-stop running time I had was 24 mins which it takes for the tank to
become empty at around 1800 RPM.
Since this was a first engine that I designed, I can say it was very challenging and as usual you will learn a lot during constructions which you never come across when following a plan that was done by someone else.
Here you can see some pictures of parts during constructions
http://www.homemodelenginemachinist.com/f31/my-single-cylinder-engine-18319/
During the constructions, I came across lots of issues and question and without the help of this site, I would have never been able to completed this engine.
Here are the links to questions I submitted during the work.
http://www.homemodelenginemachinist.com/f26/another-engine-design-question-15961/
http://www.homemodelenginemachinist.com/f26/piston-skirt-below-bore-bdc-15957/
http://www.homemodelenginemachinist.com/f26/12l14-valve-seat-cage-16138/
http://www.homemodelenginemachinist.com/f26/spark-plug-location-16558/
http://www.homemodelenginemachinist.com/f26/machining-valve-seat-16650/
http://www.homemodelenginemachinist.com/f26/ringless-piston-question-16672/
http://www.homemodelenginemachinist.com/f26/need-help-cam-design-16756/
http://www.homemodelenginemachinist.com/f26/piston-pin-off-center-17164/
http://www.homemodelenginemachinist.com/f26/carburator-question-18813/
http://www.homemodelenginemachinist.com/f26/help-belt-size-timing-pulley-18308/
http://www.homemodelenginemachinist.com/f26/flywheel-becoming-loose-setscrew-used-19755/
http://www.homemodelenginemachinist.com/f26/carburator-fuel-line-question-19743/
http://www.homemodelenginemachinist.com/f26/issue-cam-tappet-need-help-19831/
http://www.homemodelenginemachinist.com/f26/crankshaft-went-kaboom-please-help-19862/
Vertical-One
Cylinder: Steel
Timing:
EO: 40 degree BBDC
EC: 15 degree ATDC
IO: 10 degree BTDC
IC: 5 degree ABDC
