Looks good Chris,
Do you have trouble with the cranks slipping on the main shaft when running I found I have to be very careful how much air pressure I put in or the grub screws slip when I run mine.
I have not had them slip yet. Then again it has only run a couple of times at about 10 to 15 psi. I'm afraid if I go any faster this thing will explode!
