No2 Elmer's Twin Vertical Wobbler Finished
vascon2196
I was building this engine at home while building a different one at work. This engine runs FAST...
Not as shiny as the others like it on the forumn but it runs fast.
Chris
That little guy does run fast!!!! ;D
Looks like great workmanship too!!!
Just as a matter of interest:
Which engine turned out better??
I am presuming you have much fancier equipment at work, but thought i would ask! :)
Andrew
Looks good Chris,
Do you have trouble with the cranks slipping on the main shaft when running I found I have to be very careful how much air pressure I put in or the grub screws slip when I run mine.
Rob.....
Hi Rob,
I have not had them slip yet. Then again it has only run a couple of times at about 10 to 15 psi. I'm afraid if I go any faster this thing will explode!
Chris
Another measure of a quality build can be how slow the engine will run. Nice job.
Nice work! It sounds really smooth.
Thanks again...
The other engine was the larger one in this picture.
Chris
