George_Race
- Jul 28, 2010
- 125
- 2
I have been lurking around here for several months, and I must add, enjoying every visit. I am really a novice machinist, learning something every day. I am fascinated by the "Miser" Stirling engine due to the fact that it runs on just hot or cold and does not require any external fuel source to operate.
I ordered Jerry Howell's print set and misc pieces for his "Miser". After a lot of research I am finally going to start the build, one part at a time. I have a small CNC mill and a small lathe. I do not have a 4th axis on my mill, but I do have a 3 jaw chuck indexer that will help with some of the round part machining and drilling on the mill.
Now that I have decided to jump in, I spent this evening making a materials list for the engine. Was quite surprised that one did not come with the prints. Maybe he figures that most just go to the junk box corner and dig through until they fine what they need, but, when you are new to the whole process, the junk box is very empty!
From what I can see, most of the materials can be purchased on line in small quantities. I have already discovered "Speedy Metals" and wonder if any of you have other favorite on line suppliers that sell in small quantities, at reasonable prices I must add!
In looking through the various kinds of steel, I have no idea what is meant by mild steel. I see it listed by various numbers and have no clue as to what is mild and easily machinable. Maybe someone can fill me in one what to purchase in this area. Or, should I use cast iron where it is suggested instead of mild steel? Boy, do they get an arm and leg for that stuff! That is why I am considering "mild" steel.
I am sure I am going to need to ask a lot of questions as I start to build the engine. Any advice any of you may have to offer would be appreciated. I plan on doing a lot of pictures and updates to here on a regular basis, once I actually start destroying pieces of metal and cutting tools.
I thought I would start by attaching the material list that I generated this evening. It sure will make buying it piece by piece easier for someone who does NOT have a big junk box full of good stuff to choose from like me. I am a very detail oriented person and probably will spend more time researching, looking, planning, and scheming then I will machining. But I will stick with it and get it done!
I do plan on doing a lot of .dxf drawings for many of the parts so they can be processed into GCode for the mill. If anyone thinks that would useful information to have I will post either the .dxf files and or GCode on here from time to time as I create it. I am quite well versed in AutoCAD and will probably use it to develop some of the files. Incidentally, I do use CamBam for most of my CAD/CAM processing. To drive the mill I use Mach3.
All comments and suggestions greatly appreciated.
George
View attachment Raw Material List For Miser Stirling.doc
George
