Do you ever doubt yourself when looking at a job?
WELL DON'T
The MK I eyeball is more accurate than you think.
Over the years I have bought no end of fancy gadgets to help me speed up what I do in the workshop.
Some have been a help but often I still fall back on old tried and trusted methods.
Take centering a shaft up in the mill for cutting a keyway or cross drilling. I have tried edge finders and split the difference, a dowel with marker blue on and touch each side till it rubs then split the difference, one of those upside down vee things with a pointer on and loads of others, only to go back to the time honoured method of dobbing the cutter down on the work and looking at the marks, a bit like reading tea leaves.
Well talking to someone the other day about this he reckoned that it wasn't accurate enough and had to be to within two tenths of a gnats left bollock etc
So I decided to do a mythbuster.
In the following pic the shaft has been centred up bang on using edge finders and the mills DRO and the spot on the left is a 6mm cutter just touched on the work, notice the overlap both sides as being equal as it should be.
Now the spot on the right is with the DRO moved off centre by 2 thou, no bullshit, just 2 thou, now note the uneven over lap.
So the MK I eyeball is good to at least 2 thou.
WELL DON'T
