Beachside_Hank
- Oct 26, 2012
- 71
- 27
Yet Another Wobbling Newbie here, showing my progress on the build.
I decided to use the L.M.S. Wobbler Kit #2594 as a shakedown project for my 16 Sieg lathe I got from Micromark. Id spent considerable time detailing the machine and putting in the mods that seemed most useful for it, and so wanted to see what shed do for me. All in all Im very happy with it and found only one small issue, that being the cross slide nut was loose, causing about .032 of backlash. Tightening the nuts mounting screws put me in the more acceptable range of about .010- .012, that being good enough for my work and a good number in general.
So far Ive got the cylinder, upright, and flywheel in process. I played with some vision of what I wanted the cylinder to look like- more cylinder that block- and the flywheel was destined to have lightening holes around the spoke area. I used a vector drawing program to get hole spacing, cut and cemented it to the blank and drilled away, now I just need to finish turning to dimension.
