mklotz
Fooling around with my sine bar protractor
http://www.homemodelenginemachinist.com/index.php?topic=969.msg6664#msg6664
the other day, I realized that the principle could be used to build what may be the world's simplest indexing head. I have no need for it and thus no intention to build a prototype so I'll throw the idea out here for anyone who may wish to use the concept.
Imagine a circular plate that can pivot on a stationary base. A pin of diameter d1 is mounted to the base near the plate at a distance r1 from the center rotation. A pin of diameter d2 is mounted near the edge of the circular plate at a distance r2 from the center of rotation. Call the "zero" angle of the table the point where the two pins are as close to each other as possible.
Now, if I want to rotate the plate to an angle theta relative to this zero, I calculate the chordal distance from the law of cosines.
c = sqrt [r1^2 + r2^2 - 2*r1*r2*cos(theta)]
then, with the definition
d = (d1+d2)/2
I set my calipers to a distance equal to s = c + d and rotate the plate until the distance between the pins corresponds to s. Piece of cake.
While this probably won't replace a real indexing head for repetitive operations, it has some real advantages for the tool-bereft novice...
No need to buy pricey tooling to set a one-off oddball angle.
Accuracy determined only by one's ability to measure simple linear distances.
If one can tolerate a pin hole in the part (or machine the hole away later), the part itself can replace the "circular plate" I refer to above.
If anyone tries this idea, please report on what you did and how it worked.
BTW, if you wish to use the idea and are overcome by the mathematics of calculating "c", let me know and I'll write a program to do it for you.
d = (d1+d2)/2
