Hi Folks,
I worked on the construction of ''BILL LEARS'' lear fan aircraft for four years, what I remember of it was that the material was at its most dangerous state when in the ''uncured'' condition...IE...the resins in the material not being in the cured state...the material itself , when cured can be drilled using tungsten tipped drills and cut mainly with diamond coated saws or router bits... to mill the material would need tungsten or diamond bits...it depends on the quality and build structure of the material on what use you can put it to...in some cases it can ''Delaminate'' with drastic results...the dust from the material can short circuit electronics if allowed to build up on machines...it can be fairly agressive on slide ways e/t/c...I do not tkink it is any more damaging to ones health than cast iron dust e/t/c that is unless cutting it in the ''UNCURED'' state...I still have the splinters from part of the ''WING'' mould splash in my hand almost 30 years since and no ill effects ;D
All the best for now,
John.
